Anti-cancer hat
Discussion in 'Off-Topic' started by cmartinez, Jan 8, 2015.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,696
    2,748
    Very interesting article about new techniques for brain cancer treatment:
    "It is designed for people with glioblastoma to wear for 18 hours a day, while military-grade ceramic transducers within the hat pulse alternating electrical fields into the brain. These fields interfere with the protein framework that's essential for cell division, preventing the replication of malignant tumour cells, which divide far more often than healthy adult cells."
    I wonder how complex the electronics of this device might be.
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    That shouldn't be too difficult for the brain since brain cells don't divide. You might get a terrible case of dry skin as the skin dies and stops replicating though.
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    how about microwave emitters on the walls for heating? the high frequency will prevent canceer cells from dividing!!
  4. GaryCole
    Jan 6, 2015
    Interesting article, a lot of new I found for myself
  5. djsfantasi
    Apr 11, 2010
    2,899
    870
    Cynically, I wonder if the electronics are as complex as this device?
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    The meat of the study is described rather late in the link (Kaplan-Meier survival plot):
    Inhibitors of cell division are not new in the treatment of cancer. Even the ancient drug colchicine (http://en.wikipedia.org/wiki/Colchicine) has been investigated for its efficacy in treating various cancers. Whether this device actually inhibits cell replication does not seem to be shown.
    John
    Edit: I forgot to say that Optune was not the sole therapy. It was used in addition to BSC.
  7. Kermit2
    Feb 5, 2010
    3,838
    961
    normal healthy adult humans are continuously developing cancer cells in various parts of their bodies. also a surprising large amount of our normal diet are foods which contain naturally occuring cancer causing chemicals.
    Cancer and a persons freedom from it are a common myth. 99.9% of being cancer free is in having a normal healthy immune system. That one thing is responsible for destroying the constantly occuring growth of cancer cells in all healthy adults.
  8. takao21203
    Apr 28, 2012
    3,577
    463
    Certain chemicals increase the statistical cancer cases thats a fact.
    If you inhale mercury all day, have a bungalow with asbestos and lead paint that is grilled by heat, and eat junk food all day and handle PCB oils every day on your job + work in your basement on the weekend which emits radon, overdo it with ozone generators in each room, you'll very likely get a kind of cancer at some point of time.
    Governments of course are paranoid of just one kind even if it is just present somehow, so a trace of lead in some paint that is never touched, needs a sanitation team to roll out and decontaminate the area.
    The limits are set so even 1/100 is too much.
    Some researchers who made x-ray tubes actually got cancer pretty quick, same as radium dial factory workers.
    Commodore CSG had a large tank in the basement where they stored chemical waste, there are rumours at some point of time it started to leak, thats how it often goes, so there's ROHS now and all sort of guidelines, if you make one solder joint in the educational institution you are barred to do so unless the instructor switches on the solder vapour sucking system for the whole room, doesnt have the key, make a solder joint, get dismissed for the rest of the day.
