if the AM transmitter need to put the antenna, normally how the antenna in the schematic diagram?
C Thread Starter cpleng7 Joined Dec 18, 2008 120 Sep 8, 2009 #1 if the AM transmitter need to put the antenna, normally how the antenna in the schematic diagram?
hgmjr Joined Jan 28, 2005 9,027 Sep 8, 2009 #2 Take a look at this partial list of electronic symbols. Aerial is the same as antenna. hgmjr
C Thread Starter cpleng7 Joined Dec 18, 2008 120 Sep 8, 2009 #3 thank hgmjr. can you tell me what is correct way drawing the antenna. is that can straight away connect to the output?
hgmjr Joined Jan 28, 2005 9,027 Sep 8, 2009 #4 One symbol for an antenna (aerial) is the one that appears on the fifth row second symbol over. It is labeled "aerial". hgmjr
C Thread Starter cpleng7 Joined Dec 18, 2008 120 Sep 8, 2009 #5 thanks can you tell me how to connect to the circuit? why when i use the orcad simulation there are error exits in the aerial
