Antenna impedance
Circuitboy
Joined Aug 27, 2006
If I have two vertical antennas, one resonates at 5mHz and the other resonates at 550mHz, Why would the feed impedance differ?:eek:
KL7AJ
Joined Nov 4, 2008
2,229
If ALL the dimensions are scaled precisely, the feedpoint impedance will be the same. However, you must scale the diameter of the conductors as well; a conductor that looks like a piece of wire at 5 MHZ may look like a 55 gallon drum at 500 MHz!
eric
