I have 2 modules a transmitter and a receiver which both come with an antenna. On the receiver it has 2 solder points ant ground and ant next to each other, which I connect to the antenna. On the transmitter it only has ant, no ant ground. I assume that I connect the antenna to the ant point and attach it the ground of my circuit as there is no ground solder point?
