Antenna + Frequency Multiplier
Discussion in 'General Electronics Chat' started by AWD1, Feb 10, 2016.
  1. AWD1
    Feb 10, 2016
    Is it possible to have a simple set up of an antenna receiving 2.4GHz, passing through a passive frequency multiplier (given the RF wave has sufficient power to drive the component) to be doubled and then re-emit the doubled frequency from the same antenna?
    Thanks.
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    It certainly is.....and in general that's something you want to avoid! Cell phone installations, in particular are increasingly more aware of "passive intermodulation distortion" which is non-linear "diode like" properties of many metal to metal connections. Unfortunately some of these connections require far LESS power than an "official" mixer to do their dirty deeds!
    Eric
    Lestraveled likes this.
  3. Lestraveled
    May 19, 2014
    1,957
    1,217
    +1 on what @KL7AJ said.
    Great efforts are used to avoid just what you are looking for.
  4. AWD1
    Feb 10, 2016
    I'm only looking for a simple location method that works over a range of 5m/15ft.
  5. Lestraveled
    May 19, 2014
    1,957
    1,217
    Look at this data sheet.
