Antenna extender for sim900a module
Discussion in 'General Electronics Chat' started by aamirali, Aug 11, 2014.
  1. aamirali
    Feb 2, 2012
    415
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    an antenna length of 1 mn would not work, the wavelength is much shorter. 900 mhz antenna is about 35 cm, and 1800 mhz is about 17.5 cm.
    also, if you are in the US, it woluld be illegal to modify the antenna on the module.
  3. aamirali
    Feb 2, 2012
    415
    1. then what is the maximum antenna lenght I could increase.
    2. I have to modify the design for it. but current antenna is very small
    Edit: as you had mentioned, is the actual antenna is maximum lenght I could have
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
