Answer check to average power (simple)
Discussion in 'Homework Help' started by ihaveaquestion, Sep 20, 2009.
  1. ihaveaquestion
    Thread Starter Active Member
    May 1, 2009
    314
    I've checked my work at least 4 times now and I see absolutely nothing wrong, but apparently my answer is wrong.
    http://img23.imageshack.us/img23/2991/imgdi.jpg
    The answer in the back of the book is 11.3 W through R1.. I'm obviously not getting that.... what's up?
    Thanks in advance.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Taking a different approach I calculated the impedance seen by the source.
    I get Z=4.6-j1.2 ohms
    This gives an RMS current of 2.38A from the source.
    So the current in the 1 ohm resistor is 2.38A rms.
    Hence power in 1 ohm, P = 1x(2.38)^2=5.66 Watts
    So we have even more confusion with 3 different answers!
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Interestingly 5.66 W is close to half of 11.3W .... this might be worth considering - maybe the book is wrong ....???
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    I have run a simulation of the circuit to check values - 5.66W looks about right. Have you double-checked that you have correctly transcribed everything from the book problem statement to your working notes?
  5. ihaveaquestion
    May 1, 2009
    314
    I have double and triple checked, haha...
  6. ihaveaquestion
    May 1, 2009
    314
    I've caught the book being wrong at least 3 times now....
    I still can't find out what's wrong with my approach though...
  7. The Electrician
    Oct 9, 2007
    2,300
    335
    I get the same result that tnk does, calculating the impedance seen by the source.
    One error I see in your calculations is in the 4th equation down under the heading "For I1".
    You have:
    j6 I2 = -12.3 + 10.3 + I1(1 + j6)
    You divide left and right side by j6 and get:
    I2 = -1.72 - j2.05 + I1(-1 + j0.167)
    but you have sign errors; the result should be:
    I2 = +1.72 + j2.05 + I1(+1 - j0.167)
    This propagates to your final result causing a substantial error. There may be other errors, but I stopped looking when I found that one.
  8. ihaveaquestion
    May 1, 2009
    314
    The line I think you're looking at is 6i I2 = -12.3 + 10.3i + I1(1+6i)
    I just plugged into my calculator (-12.3 + 10.3i) / 6i for the part without I1
    and it gives me -1.72 - 2.05i
    Then plugging in again (1+6i) / 6i for the I1 part
    it gives me -1 + 1/6i
    So I2 = -1.72 - 2.05i + I1(-1 + 1/6i) which is my reasoning for having that written
  9. The Electrician
    Oct 9, 2007
    2,300
    335
    Let's try doing it by hand.
    We know that 1/(6i) = -i/6
    then, for example, taking just the real part of (-12.3 + 10.3i) we would have:
    -12.3/6i = -12.3 * -i/6 = (12.3/6)i = (2.05)i = 2.05i, not -2.05i
    And for the imaginary part:
    10.3i/6i = 10.3i * -i/6 = -(10.3i/6)i = -(1.72)i*i = 1.72, not -1.72
    So your calculator is saying that (1+6i) / 6i = -1 + 1/6i
    Let's do it part by part.
    (1+6i) / 6i = (6i + 1)/6i = 6i/6i + 1/6i
    Where does the -1 come from? 6i/6i = 1, not -1.
    Next consider the second part. 1/6i = -i/6 = -0.167i, not +0.167i, as you have in the image attached to post #1.
    Unbelievable as it may seem, apparently your calculator is getting the signs wrong. What kind of calculator are you using?
  10. ihaveaquestion
    May 1, 2009
    314
    What you're saying makes sense Electrician... very frustrating.... it's a Casio 115ES
  11. ELECTRONERD
    May 26, 2009
    1,146
    16
    I have the exact same calculator. :rolleyes: Funny it isn't working like it should...
  12. The Electrician
    Oct 9, 2007
    2,300
    335
    What do you get if you calculate 6i/6i?
  13. ELECTRONERD
    May 26, 2009
    1,146
    16
    For some reason I can't use "i" in my calculator. It isn't working...I need to know what settings the calculator should be on...
  14. ihaveaquestion
    May 1, 2009
    314
    I just pressed the Mod/Setup button and pressed 2 for complex numbers.
  15. ihaveaquestion
    May 1, 2009
    314
    How stupid... you have to put parenthesis around (6i) to get the right answer... i.e. (1+6i) / (6i)
  16. ihaveaquestion
    May 1, 2009
    314
    Pretty sure I'm still not getting right answer with right calculations...
  17. ELECTRONERD
    May 26, 2009
    1,146
    16
    Ok, I have the CMPLX on the screen but I press A and then the <Shift> ENG button to get i, but it won't come out.
  18. ELECTRONERD
    May 26, 2009
    1,146
    16
    Nevermind, I figured it out. When you do (1 + 6i) / (6i) I get 1 / (-1/6i). Is that what you get? I do have the right "i" don't I? :D
  19. The Electrician
    Oct 9, 2007
    2,300
    335
    You should get (1 + 6i)/(6i) = 1/(6i) + 6i/6i = -.0167i + 1 = 1 - 0.167i
    I redid the calculations under the heading "For I1"
    When you get down to the place where you had the sign error, you should have:
    I2 = +1.72 + j2.05 + I1(1 - j0.167)
    Then substituting I2 = (j6 I1)/(2 + j4) you should have:
    j6 I1 = (2 + j4)(1.72 + 2.05 + I1(1 - j0.167)
    and finally:
    I1 = (-4.76 + j10.98)/(-2.67 + j2.33) = (3.05 - j1.44)
    The magnitude of I1 is 3.375 amps.
    The average power is 1/2*(3.375)*(3.375) = 5.695 watts
    Your numbers may be slightly different due to rounding error from using only 3 digits in the arithmetic, but this is essentially the same result tnk and I got using the impedance seen by the voltage source.
  20. The Electrician
    Oct 9, 2007
    2,300
    335
    Anyone who is going to do a lot of complex arithmetic should have a calculator that isn't going to have weird behavior that trips you up like this Casio. Imagine if you were trying to solve a problem on an exam and didn't know about this peculiarity!
    I would recommend something like a TI89 or HP50. You can get those on eBay for a quite reasonable price. Instead of the current production HP50, get the just barely obsolete HP49G+ for less money, but the same performance.
