Another Transistor Checker
Discussion in 'The Projects Forum' started by nomurphy, Jul 23, 2012.
  1. nomurphy
    Thread Starter AAC Fanatic!
    Aug 8, 2005
    567
    12
    The attached is an old design from Altec, note the use of a germanium xstr and positive ground. Runs from 3VDC, relatively simple to build.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Please read the rules of the Completed Projects forum.
    Have you actually built this project? It is a requirement, and a picture is strongly encouraged as part of the first post.
    A parts list, and a visible schematic are also needed. Basically this was spelled out in the requirements listed in the sticky.
    Basically we have bumped up the quality of submissions. This is not to keep you from submitting projects, but increase the quality of the submissions.
    Basically I will give this a week to be brought up to snuff. If this is not down the thread will be moved to the Projects Forum. If this happens you can still correct the entry and it will be moved back, there is no dead line for this.
    Anything I can do to help this process please ask.
