Another thevenin problem :> (but I'm almost done finished!)
Discussion in 'Homework Help' started by Kevin2341, Mar 4, 2013.
  1. Kevin2341
    Nov 1, 2009
    19
    sorry, figured my question out
  2. WBahn
    Mar 31, 2012
    18,064
    4,904
    Because your thevenin equivalents aren't correct.
    Aside from still being sloppy with your units -- I will soon stop trying to help you if you don't start tracking your units -- you are making the classic mistake of grabbing the nearest V and the nearest R and thinking that if you throw them at Ohm's Law that you get some kind of current that means something. When the circuits are hooked up, is the 100V appearing ACROSS your 3000 ohm resistance? No! Also, since the three resistances and the two sources are all in series, don't they all have to have the SAME current?
    BTW, the "funky number" is correct.
