Another Series-tuned, Shunt-fed Crystal Radio
Discussion in 'Wireless & RF Design' started by vu2nan, Oct 12, 2015.
  1. vu2nan
    Sep 11, 2014
    43
    10
    This shunt-fed crystal radio is housed in a plastic pencil box.
    It has 2 windings of 30 SWG enamelled copper wire on a 6" long, 3/8 " diameter ferrite rod. The primary has 10 turns and the secondary 90, both close-wound.
    Series-tuned, Shunt-fed Crystal Radio - Schematic
    The primary series-tuned circuit, which includes the 200μH moulded inductor and the capacitance of the 60' short- wire antenna, is resonant at 612 kHz (the frequency of the local 200 kW station located 20km away. The secondary is also series-tuned using a 500pf PVC variable capacitor. The detector, a germanium transistor with its base and emitter connected, shunt-feeds sensitive balanced-armature phones.
    Series-tuned, Shunt-fed Crystal Radio - Inside view
    Reception of the local station is quite good with headphone current being 400 μA (measured using a 1mA FSD 60 Ω meter).
    Regards,
    Nandu.
    BR-549 likes this.
You May Also Like:
Load More
