another sa612 question
Discussion in 'The Projects Forum' started by silky, Apr 11, 2013.
  1. silky
    Apr 10, 2013
    High all, new user here.
    I was planning to mix the attached 15 mHz WWV trace (turn up your volume),
    to a LO I made (10mHz) by feeding the LO, 200-300 mv p-p through a cap to pin 6 as the data sheet says i can, the question being is this rf signal large and clean enough to give me a 5 mHz IF? It looks like it's around 200 mv p-p
    also. I will never understand impedence matching, so don't even try.
    Silky
  2. k7elp60
    Nov 4, 2008
    481
    69
    Since the mixer is double balanced if I remember correctly the output of the mixer will have two signals. 1 the sum of the LO and the Input, and 2 the difference of input signal and the LO. So you will need a tuned circuit or a filter of some sort at the difference frequency.
    silky likes this.
  3. silky
    Apr 10, 2013
    k7elp60, thanks for the response. Yes I am hoping to send the output through
    a 5mHz xstal ladder. Will the output from the 612 be around 100-200 mv as well? Will I need an amplifier or a follower before or after the follower? At any rate I will soon try
    it sans and see what happens. tnx agn 73
  4. k7elp60
    Nov 4, 2008
    481
    69
    I am not sure what your output level will be. You might want to study the data sheet as the mixer has quite a bit of gain.
