Another question Base Resistor
Discussion in 'General Electronics Chat' started by BReeves, Nov 7, 2013.
  1. BReeves
    Nov 24, 2012
    412
    64
    Same schematic as my question on the logic of leaving the opto LED on.
    Q2 is a BD137, hfe ~ 40, the counter has a 92 Ohm 12 volt coil. When I calculate the base resistor for Q2 I come up with 3.3K. Whoever designed the original control board felt 10K would put Q2 in saturation. What am I missing, big difference between 3.3 K and 10K?
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    What you are missing is how much collector current is flowing. You need to know that to pick the base resistor.
    That, and the number you keep in your back pocket. Most people keep a "10" there to give the base 1/10 the collector current. I have a "20" there for small signal stuff.
    It's not a hard and fast thing.
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    {12-Vcesat) = ~11V
    Icoil = 11/92 = 120mA
    Ib = Ic/10 = 12mA
    Rb = (12-0.6)/12m = 0.95K, call it 1K
  4. BReeves
    Nov 24, 2012
    412
    64
    I did neglect the voltage drop across the transistor and used the transistors gain :mad:
    3K is allot closer to 1K than 10K but still leaves me wondering how the original designer would come up with 10K
    Just did a quick lets-see, if the transistor had a current gain of 120, 10K would be about right. We know 10K works as the machine is working with the old controller. This means in reality anything from 1K to 10K would work. At least till someone replaced the transistor with one that actually only had an hfe of 20.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    When you're using a transistor as a saturated switch, you really do want to use the Ib=10 figure. However, in this case you're up against a troublesome design; if you DO decrease the 10k base resistor for Q2, it'll wind up with increased power dissipation. A 1k resistor will have around 144mW power dissipation when the optocoupler output is conducting, requiring a 1/4W resistor. There's also the limitation of the optocouplers' output to sink that much current; depending on the model you might be limited to somewhere around 3mA; and as the optocoupler ages, that will get worse. This is most likely the reason the base resistor chosen is so large. I suggest that the design you have presented is somewhat dubious. Datasheet for the BD135:
    http://www.fairchildsemi.com/ds/BD/BD135.pdf
    See Figure 1 and Figure 2 on page 3; I think it's likely they looked at those curves and then fudged it due to the optocoupler's low current sinking capacity.
  6. BReeves
    Nov 24, 2012
    412
    64
    Thanks, that makes sense..
    I am also controlling it with an opto but the one I am using has an output transistor rated at 50mA. 3.3K will result in ~3.64 mA, well within spec. A 1K would be ~12mA still within spec.
    I may just split the difference and use a 2.2 K ;)
    I probably should add that I will not use the reverse logic of the original design. I will simply turn on the opto for ~50ms when it needs to count.
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Lots of experience? Most of those small transistors will run an actual beta easily over 100 when driving a 120mA load. So a 10k Rb is low enough.
    Also keep in mind that there are different levels of "saturation" and if you can tolerate (say) 1v drop across the transistor Vce when on, you can achieve that low-ish level of saturation at a beta of maybe 200-300. That still leaves 11v for the relay coil, plenty enough to ensure pull-in, AND reduces coil current and coil heat by a small amount too.
    If in doubt, build it and test it. :)
