Working on a "special" project and doing some electrical work. I've got everything wired correctly and it's all functional. The next hurdle before I can finalize it is that I have a control board that I need to:
A: See if I can at all re-size it/cut part of the board off to condense it, as it will need to fit into a small space, aka, an arm-glove.
B: Remove the Tact switches, and essentially extend them from the circuit board to extend to a desired length.
To give you an idea, I'm placing the control board into a glove/sleeve on my arm, probably on the bottom-mid arm area. I need to operate the switches from my palm (think Spider-man web shooters).
I already removed the tact switch and was testing but I cannot seem to figure out the right way of going about it. It has 5 holes, 3 of which actually appear to be in contact with the etched circuit pattern. I'd like to see if someone would be able to help me to figure it out!
As for cutting it down, I don't think I could honestly do it without affecting what I need, but it's a long rectangular board and the smaller the better for this application
Here are some pics of it:
Other side
Thanks for the help! It'll be a cool thing to show when it's all working as I envision it!!
-TC
Other side
-TC
