Another IR2110 Problem 2 amps? And im new here!
Discussion in 'The Projects Forum' started by XPCam, Jan 12, 2015.
  1. XPCam
    Jan 12, 2015
    5
    Hi im new here therefor Hello to everyone!,
    Im trying to build a metal detector using an IR2110 mosfet driver. I use 12 volts to drive the coil and to fed the mosfet driver. I use the driver as two low sides with 2 mosfets sepperated coil drivers. The fets i use are IRFS31N20DTRL that gives mee max 200v 30A and Rds-on is 0.082 Ohm but when im pulsing the driver the driver will take 2 amps is this oke?! at 10v it is taking around the 0.5 amps and i cant figgure out why its taking that mutch amperage.
    Im wondering why this occures beqourse it likes to schrink my batteries by the minute :)
    Christian (The Netherlands)
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    Can you post a schematic of your setup?
    You can use the Upload a File button below the reply window to attach the image.
    Bertus
  3. XPCam
    Jan 12, 2015
    5
  4. XPCam
    Jan 12, 2015
    5
    This is the Schematic i used.
  5. Alec_t
    Sep 17, 2013
    5,971
    1,135
    What are the input pulse parameters?
  6. XPCam
    Jan 12, 2015
    5
    5v digital with a 10k resistor pulselength 200uS and closed time is 1000uS i tried to disconnect both coils and tried again and the mosfets get up to 100 degrees in a minute can it be the resistors at the gate? Ill try to replace those with 2 100nF's
    Christian
  7. XPCam
    Jan 12, 2015
    5
    Problem Solved...
  8. shortbus
    Sep 30, 2009
    4,095
    1,681
    Please post what problem you found, and what you did to fix it, to help others that in the future have a problem like this. :)
