Another day, another lesson (homemade PCB)
Discussion in 'General Electronics Chat' started by Georacer, Oct 13, 2012.
  1. Georacer
    Thread Starter Moderator
    Nov 25, 2009
    5,151
    1,266
    So I've been building a PCB these days. Eagle, dual layer, through-hole parts, the works.
    So after I designed, printed, masked, etched and soldered the PCB I realized this:
    There was no electrical connection between the IC pins and the top layer pads, nor was space for solder to create one.
    Cursing ensued.
    Let's just say that v0.2.1 of that board will work around that problem.
  2. kubeek
    Sep 20, 2005
    4,687
    805
    Why can´t you solder the top traces to the pins? I managed that even with sockets, so it should be possible. The half melted socket looks horrible, but it works.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Do not use the el cheapo sockets. Use the type that cost somewhat more. And yes in a non plated hobbyist board. Both sides must be soldered since the board will not have through-plated holes.
    Here is a picture The socket to the right is the el cheapo type. That I never use. The one to left is solderable from both sides on a hobbyist board and much better overall quality
    Edit: And as Kubeek says. This type of socket may be some scorched then soldering on the top layer. But it will still work.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    The most expensive one costs at about 50c more that the cheap one, IIRC. It could be worth it since it saves me from soldering a via for each pad I solder on top.
    But I still can't get around pin connectors and headers that go as low as the board surface.
  5. Ron H
    Apr 14, 2005
    7,050
    657
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Use a really thin wire to connect the top and bottom pads. Solder away from the pads. As long as you are not carrying current through it it should work.
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    I believe you are referring to chemical methods, right?
    I must admit that I 'm not familiar with any, and I don't think that they are worth it for the prototyping phase. What do you think?
    @Bill,
    I don't want to plan beforehand where the power needs to go. I 'll stick to making a via next to the pin, for now.
    If I get more comfortable with recognizing all of the power paths on a board, I 'll use your method. Soldering a very thin wire on a trace under tension sounds like work, though.
  8. bountyhunter
    Sep 7, 2009
    2,498
    507
    Far from the dumbest mistake I have seen on PC boards.... I should write a book.
    What was really funny was a board we had made where all the pads and vias were done right, but the knothead who made the fabrication drawing was too lazy to spec the right size holes for the larger resistors and caps and diodes.... so the assembly tech just took a drill and drilled the holes out so she could assemble the boards.
    Funny trying to troubleshoot a board where the top layer traces don't make contact to half the components on the board.....:p
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    Not funny, man, not funny.
    I virtually copied the top layer under the bottom one using wires.
    I just hope I roll out the next version soon enough so that I don't have to look at this atrocity. And it was so pretty off the bath...
  10. Bernard
    Aug 7, 2008
    4,233
    414
    Reminds me of way back when [before plated thru holes ], " we " speced PCBs with fluted eyelets from TI-- they realy did make custom boards.
  11. Georacer
    Nov 25, 2009
    5,151
    1,266
    You speced (?) them with what? What's a fluted eyelet?
  12. nerdegutta
    Dec 15, 2009
    2,565
    805
    December last year. I made this:
    I just forgot to scale it properly. I had earlier experimented with the scale, and forgot to set it to 1:1. This board is made in 1:1.3.
    The 555 IC didn't make the split...:)
  13. t06afre
    May 11, 2009
    5,939
    1,222
    Not very high standard either I would say:p
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    That is the neatest, most beautiful failure I have seen in a long time. :)
    I too made a beautiful failure PCB using toner transfer. After getting the toner density perfect and transfer perfect and every trace checked as being perfect, (guess?) I realised I had forgotten to flip the artwork and the PCB was backwards. :eek:
  15. Bernard
    Aug 7, 2008
    4,233
    414
    The name has changed from fluted to funnel. " What is the purpose of funnel flange eyelets ?" Specifically developed for electronic use, funnel flange eyelets allow solder to flow around the barrel. Lead wires are easier to insert and solder fillet is quickly inspected." Internatoonal Eyelets Inc.
    SgtWookie and Georacer like this.
  16. Georacer
    Nov 25, 2009
    5,151
    1,266
    That happened the first time I went out to a photo shop to print my mask. Luckily I checked it before taping it. I went back to the shop to complain. The owner said "that's what the printer gives, I can't do anything else."
    The next shop printed it just fine.
    I 'm feeling competitive, so here's my beautiful failure. Drilled too!
    I still can't manage the camera flash settings correctly.
  17. Georacer
    Nov 25, 2009
    5,151
    1,266
    So it's a copper sleeve inserted in the whole and soldered on both sides. Clever, but a lot of work.
  18. t06afre
    May 11, 2009
    5,939
    1,222
    A trick I use. Is to print out on paper then place some components on the paper. Like big ICs. This will give some clues on how your scaling is.
  19. t06afre
    May 11, 2009
    5,939
    1,222
    If you work with through holes ICs. The decoupling caps makes a very good via. Must still be soldered on both sides although
  20. Georacer
    Nov 25, 2009
    5,151
    1,266
    Yes, I, or better, the Eagle software uses the pads to switch between layers.
    From now on I just have to restrict routing from the top side pads that can't be soldered upon. The change has been done in the version 0.2.1 of the board.
    It pulls the track a bit off the bottom pad and creates a via next to it, where I can solder through it.
    I 'm quite happy with the options I 'm given by this software.
