Another Crystal Radio with Air Core Coil
Discussion in 'Wireless & RF Design' started by vu2nan, Aug 7, 2015.
  1. vu2nan
    Sep 11, 2014
    43
    10
    This is an improved version of my Crystal Radio with Air Core Coil.
    The coil is 75turns of hook-up wire, close-wound on a 2 ⅝" diameter plastic bottle, with a tap at 35 turns.
    The 35 turn primary series-tunes the capacitive 60' random wire antenna to resonance at 612kHz (frequency of the lone 200kW local AM broadcast station). The secondary is parallel-tuned using a 500+500 pF PVC gang condenser.
    The plastic bottle serves as the coil former cum enclosure. A screw-type terminal strip is used to connect antenna, earth and headphones.
    Reception, using sensitive balanced-armature headphones, is quite good.
    Regards,
    Nandu.
      File size:
      8 KB
      18
      File size:
      16 KB
      17
