Size 34 for $137 + tax.It's been so long that I've been out and about, may I ask what group size and the cost?
No worries. It'll automatically turn the stereo off if it detects excessive battery drain, so that it won't need to be jump started. But it's true that you won't be able to listen for very long before it shuts off.That thing has a reserve of only 10 amp hours. Don't listen to the stereo with the engine off.
It will also turn off the ECU, TCU (both now needing a relearn) and many other electrical needy things in a modern car with the radio, that might now need the stupid anti-theft radio code to work again. Li cells are great but you can't run them close to flat and recover like a Lead-acid battery. Make it full capacity and I will consider it.No worries. It'll automatically turn the stereo off if it detects excessive battery drain, so that it won't need to be jump started. But it's true that you won't be able to listen for very long before it shuts off.
by Robert Keim
by Jake Hertz
by Duane Benson
by Jake Hertz
