Anode driver needed for common cathode display
Discussion in 'General Electronics Chat' started by CollieJim, Apr 18, 2013.
  1. CollieJim
    Nov 27, 2004
    29
    I have a large 4-digit, 7-segment, common cathode display which requires at least 7v to be visible.
    I'm using a 74HC138 to select the digit, and tried to use a 74HC238 for the anodes but it's very dim.
    Would some sort of buffer chip be useful here?
    I'm using a PIC16F1827 and a DS3232 I2C clock module.
    TIA
    Jim
  2. MMcLaren
    Feb 14, 2010
    759
    116
    Hi Jim,
    Consider using a Micrel MIC5891 eight bit serial-to-parallel high voltage driver. It has separate VCC and VBB inputs and is perfect for those higher voltage multi-LED-per-segment displays.
    Cheerful regards, Mike
  3. CollieJim
    Nov 27, 2004
    29
    Thanks. Just what I need.
