Annoying alarm generator
kuxz
Joined Oct 11, 2014
I would like to create an annoying alarm generator through the use of LM358. I've tried to generate a square wave output using this circuit (http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/square.html) and the output connected to a capacitor before going to a 8ohm, 0.25W speaker. However, I am only able to hear a monotone output. Do I need a audio amplifier circuit?
However, I am only limited to a few analog components for my project which includes:
LM358
BJT
MOSFET
resistor
Capacitor
Diode
Desired annoying alarm tone link:
kuxz
Joined Oct 11, 2014
This is the current circuit that I've built and the 8ohm, 0.25W speaker is connected after the 1uF capacitor. The duty cycle of the output can be controlled through tuning the potentiometer R1 and R4. The problem is that even though I am able to control the duty cycle of the output, the sound generated from the speaker remains to be monotone. Do I need to modulate the frequency in order to generate the tone?
Brownout
Joined Jan 10, 2012
2,390
I don't understand. You say you have a monotone generator, but you wan to generate the tone. You're gonna need to describe what the tone is.
DickCappels
Joined Aug 21, 2008
10,187
By listening to your example, it is clear that two oscillators are in use. One to make the tone and the other to vary the frequency as a function of time. Back in the 1960's we did this with a couple of neon lamps and a few resistors and capacitors. Now it needs integrated circuits?)
I have tried two different browsers. I can see your simulator output but I cannot see your schematic. Please try again.
@Brownout You can hear the tone by playing the YouTube clip.
Dodgydave
Joined Jun 22, 2012
11,306
Your missing a 100K resistor from pin 3 to pin 4 ground, the first op amp is a sawtooth generator and needs a half rail supply on pin 3.
ian field
Joined Oct 27, 2012
6,536
DickCappels
Joined Aug 21, 2008
10,187
Ditto see post #8.......
<<== Take note, you really need that resistor. I can't see how the circuit would even work in the simulator without that 100k resistor.
@Brownout, the TS is looking for a continuously varying tone rather than the bi-frequency British siren. Do you have one ready to go that drives the NE555 control voltage input with a repeating function (e.g. sawtooth, sine, etc.)?
WBahn
Joined Mar 31, 2012
30,076
Apparently there is a commercial product called an Annoyatron that would save a lot of experimenting and construction.
Yep, why waste time on experimenting and construction when solving a homework problem. Much better to just use a commercial product. Should the grade be based on how expensive the product is, or on how cheap?
