angular deccelerartion
Discussion in 'Physics' started by braddy, Nov 2, 2005.
  1. braddy
    Dec 29, 2004
    83
    I need help with the following problem.
    A skater does a pirouette at the rate of 2.0 rev / second and then stop within 3/4 rev. Assume that the angular decceleration is constant and calculate its magnitude.
    I tried to compute it but I found -18 rad/s[sup]2[/sup].
    BUt the textbook gives -17 rad/s[sup]2[/sup].
    Please can someone help me with this problem?
    Thank you
    B
  2. m-rice
    Nov 25, 2005
    Use the formula v^2 = u^2 + 2as, where v is final velocity (0), u is initial (2rev/sec) a is acceleration, and s is distance (0.75 rev)
    I get a = -16/6 rev/sec^2 = -16.755 rad/sec^2
    This is closer to the text book answer!
    Martin
    PS Did you manage to do the question about the spinning reel?
