Angle sensor
Discussion in 'General Electronics Chat' started by Dritech, Feb 21, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    Is there a sensor / module which outputs a analogue voltage with angular change? I want to use it for monitoring an object which will rotate 180 degrees. The reason for not using a potentiometer is because I am limited with space.
    Any kind of help will be appreciated.
  2. studiot
    Nov 9, 2007
    5,005
    515
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    how about a trim pot, about 1/4 inch around.
  4. bwilliams60
    Nov 18, 2012
    734
    94
    Can you be more specific about size and space available as well as voltage and amperage specifications?
  5. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    How about using an accelerometer. As an example, MXP7205VF will measure static acceleration (gravity).
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Ebay has tiny $4 accelerometer modules that output 3 linear voltages for the 3 axes. They have three output wires, marked; X Y Z.
    To compute rotary angle you will need to measure two axis voltages and do some simple sine/cos math.
  8. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the replies. The tutorial in the link below shows how to use 2 axis for measuring the angle, but the problem is that apparently one can only monitor an angle less than 90 degrees. Is this true? and how accurate can I get?
    Thanks in advance.
  9. Dritech
    Sep 21, 2011
    756
    5
  10. KMoffett
    Dec 19, 2007
    2,586
    234
    Second this! How about a photo of the location where you are trying to mount an angle sensor? It may open up other possibilities.
    Ken
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The analogue accelerometers output a voltage representing the G force of gravity. The voltage is centred. (For example) 2.5v for 0G, and 1v for +1G (upright) and 4v for -1G (upside down).
    So the voltage will show all angles not just 0-90', but you need two axes and work from sin/cos of the two voltages.
    It sounds tricky but is very simple in software. There are tons of "DIY accelerometer inclinometer" projects you could google.
