Angle sensor for large Solar Panel tracker
Discussion in 'The Projects Forum' started by TexasTony, Apr 23, 2013.
  1. TexasTony
    Thread Starter Active Member
    Jul 15, 2010
    41
    I'm onto a new project, putting up a few tracking solar 'trees' to power the house. I've already welded together the arrays (10 ft x 10 ft each) to hold the solar panels so I'm well into this. It weighs nearly 1000 lbs (array + panels) and I made a heavy duty hinge to support it.
    What I am wanting to do is have a way to sense what rotational angle is the array sitting at. The reason is in case of strong winds, I want to rotate the array to horizontal for minimal stress. Note that my hinge is a beast of a hinge, so a rotation sensor connected at the hinge is not a good idea.
    I'm finding gyroscopes, but I don't really care about the rotational speed or acceleration (in fact they will only introduce error). I just want to know what tilt angle is it at. A little IC would be great. Any suggestions?
    Tony
  2. nickelflipper
    Jun 2, 2010
    280
    35
  3. Bernard
    Aug 7, 2008
    4,231
    414
    Another acceloration-tilt sensor: Parallex MX2125, may still be available from RS. Puts out a PWM signal.
  4. TexasTony
    Jul 15, 2010
    41
    Thanks guys. That sent me in the right direction. The first part listed has actually been discontinued. But I found this one:
    http://cache.freescale.com/files/sensors/doc/data_sheet/MMA6331L.pdf
    It's called an accelerometer. But I think it will measure the tilt, and it's 2-dimension measurements. It does say to keep the microcontroller close. So I'll probably end up with 2 uC's, no big deal there. One up on my tilting array, and one down low where I can reach it.
    Thanks again
    Tony
  5. John P
    Oct 14, 2008
    1,636
    225
    You could always use old technology, a potentiometer operated off the mechanical parts. It doesn't have to be connected directly to the hinge--there could be a little linkage that operates it.
  6. mcgyvr
    Oct 15, 2009
    4,784
    973
    exactly what I was going to recommend.. its simple and just plain works.
    string pots,etc...
  7. sparemma
    Feb 11, 2015
  8. Bernard
    Aug 7, 2008
    4,231
    414
    Intresting, but it does not apply to this post.
  9. wayneh
    Sep 9, 2010
    12,368
    3,223
    Won't this require just two positions; horizontal and tilted up for normal operation? I don't understand why you'd need to know any angle in between. You just need limit switches.
  10. MikeML
    Oct 2, 2009
    5,450
    1,066
  11. crutschow
    Mar 14, 2008
    13,466
    3,356
    I agree with wayneth.
    Why not just use limit switches?
  12. Kermit2
    Feb 5, 2010
    3,838
    961
    light sensor circuit with the sensors on east and west. when one is shaded tilt drives until both sensors are equally illiuminated.
    anometer input would place panels in 'storm' parking mode. use an integrator with a long time constant to get high wind signal and ignore short gusts.
  13. KMoffett
    Dec 19, 2007
    2,584
    234
    Perhaps the OP needs to change the angle of the array with the time of year. Limit switches would be good for overrun, but a pot would be cheap and easy for angle.
    Ken
  14. mcgyvr
    Oct 15, 2009
    4,784
    973
    perhaps you all need to realize this is a post from 2013 until that spammer bumped it back to life :p:)
  15. wayneh
    Sep 9, 2010
    12,368
    3,223
    Aaarrrgh!
  16. Kermit2
    Feb 5, 2010
    3,838
    961
    2013, 2014. details details details.
    the thread was obviously incomplete! :)
