Anemometer Wind Speed Control
kris.92
Joined Nov 26, 2012
11
I have been assigned a project to use an anemometer to measure wind speed obviously, but if the speed exceeds a certain rated speed the circuit should turn on an LED. I have just considered having the the anemometer attached to the shaft of a generator and have an LED just connected in series with generator. Thinking that I would have an LED rated for a certain voltage so it wouldn't turn on until that voltage is induced by the generator, but I feel as though that is too simple or if it would work. I am not looking to cheat I would just like some input and ideas on what you may have in mind. And it is an analog circuit.
kris.92
Joined Nov 26, 2012
11
So I have come up that the zener diode in reverse bias will break down at a rather high voltage depending on the diode obviously. But, once a diode hits its break down voltage doesn't it essential burn out?
BillB3857
Joined Feb 28, 2009
2,570
Did you read the article in the link I posted in #4 above? If you did, I would suggest reading it again to get a better understanding of a Zener. You are on the right track, but need to fill in some details. Info available in the link.
kris.92
Joined Nov 26, 2012
11
K I realise I am probably missing something here but I have just wired a simple circuit on my bread board with a resistor in series with a zener diode and an LED and the LED does not light up until about 12 volts is applied to the circuit. So to me that seems kind of like a voltage switch.
BillB3857
Joined Feb 28, 2009
2,570
If you read the link, you will know that the zener diode starts to conduct when the reverse voltage reaches/exceeds the zener voltage. Do you know the part number of the diode you used. If so, google it and it will tell you the nominal breakdown voltage. Now, back to your project.... How can you use that concept to cause the LED to light if the wind speed is greater than a certain amount?
Have a look here..... http://electroschematics.com/5816/led-volt-meter/
Google can be your friend!
kris.92
Joined Nov 26, 2012
11
I was just thinking that the faster the the anemometer spun the faster the generator would spin inducing a larger voltage. Once or if that induced voltage reached the breakdown voltage of the diode it would be able to conduct and then turn on the LED.
BillB3857
Joined Feb 28, 2009
2,570
Right! Now all you need to figure out is what voltage out of the generator represents a given speed. (When I was a kid (many years ago) we held our "windmill generator" out of a car window while our buddy drove at various speeds. That way we could calibrate our system.) My guess is that your generator will not produce the voltage you want at the speed you want the LED to trigger on. If you're lucky, it will be higher. Then what will you need to do?
BillB3857
Joined Feb 28, 2009
2,570
You might want to re-think that one a little. What course are you taking and how far along in it are you. That info will help me to help me to help you find the answers.
kris.92
Joined Nov 26, 2012
11
sorry I miss read what you wrote before. I guess if the voltage is too low to break down the diode I could just slip in an amplifier.
BillB3857
Joined Feb 28, 2009
2,570
Sounds like you are on the right track. The zener concept is one that would work as long as the voltage levels from the generator were high enough to break the zener over and power the LED. No external power (other than the generator) needed. Now that you are talking amplifiers, you are adding power supplies. What component can you think of that could possibly monitor the voltage from the generator and sense when a certain level was reached or exceeded?
thatoneguy
Joined Feb 19, 2009
6,359
Most commercial spinning anemometers (speed + direction of wind) have a tiny magnet in the hub, which passes a hall effect sensor or a coil in the body. The supporting electronics then count pulses per second to calculate the wind speed.
The key is keeping the moving rotor as light as possible, and having the correct geometry blades on it. This geometry is slightly different than one used for power generation or fans, as they have a different attack angle for more "bite" into the air.
Anemometer vanes need to spin with a very low mass with a very low friction/low drag hub, trying to accomplish that while driving a load is counter-productive. Though it can be done with a modified fan blade, the results won't be as linear or accurate as you'd like.
If direction of wind isn't needed, the thermal anemometer in the circuits above is a reliable and accurate version as well.
kris.92
Joined Nov 26, 2012
11
Got it! I just was messing around with a comparator on Multisim works perfectly for what I need. Thanks everyone for the help.
