The message seems clear enough: a required file or directory is missing from the specified directory. Btw, the spelling should be "Android", not "andriod". Perhaps that's why the file can't be found?
Find out where your java executable is. It might be that Android Studio is expecting a different version of java, which would likely be installed in a different location. You might be able to edit the settings in Android Studio to point it to your current java install.
