AND GAte problem
Discussion in 'General Electronics Chat' started by Hassaan Aslam, May 3, 2013.
  1. Hassaan Aslam
    Apr 20, 2013
    11
    hi!!! i am a beginner, when i use and gate i get '1' output even if my inputs are '0'. i have tried two ic's 7408 and 4081 but i am getting same problem with both of them. can any one guide me hoe to use these ic's correctly.... :confused: :( :confused:
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    Did you remember to connect Vcc and GND correctly?
  3. Hassaan Aslam
    Apr 20, 2013
    11
    yes i had connected Vcc and ground....
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    Next step is to post a photograph of your setup.
  5. kubeek
    Sep 20, 2005
    4,691
    806
    did you connect the inputs to ground, or are you simply assuming that unconnected means logic 0?
    MrChips likes this.
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Another question is what are you using for power? The 7408 is only designed for 5 volts on Vcc. If you connected a higher voltage, you've likely damaged the chip.
    Also, what are you using to drive the inputs?
  7. MrChips
    Oct 2, 2009
    12,652
    3,461
    Yeah, I forgot about that one too.
  8. Hassaan Aslam
    Apr 20, 2013
    11
    i am currently using 4081 i am using 5 volt input but i have not connected inputs to ground.
  9. Hassaan Aslam
    Apr 20, 2013
    11
    if the inputs are connected to ground then how will i apply "1" inputs to the input terminals???
  10. kubeek
    Sep 20, 2005
    4,691
    806
    You need to have ALL inputs connected to either supply voltage or ground or output of another gate. Without that the inputs will act like antenna and will have any value.
  11. kubeek
    Sep 20, 2005
    4,691
    806
    You connect them to either ground of supply voltage. You can also connect them through a resistor to ground, for example 10k.
  12. Hassaan Aslam
    Apr 20, 2013
    11
    okay thanks all of you i will try this
  13. Ramussons
    May 3, 2013
    562
    92
    In Logic Gates, an Open Input is as good as 1, or Logic Hi.
    Ramesh
  14. kubeek
    Sep 20, 2005
    4,691
    806
    Only with TTL chips, and still it is a very bad practice to leave it unconnected.
  15. Ramussons
    May 3, 2013
    562
    92
    I would Never, Never design a circuit without following this fundamental rule!
    Ramesh
