This circuit was provided by MikeML with input from SgtWookie. I have a couple of questions (well, plenty, but I'll start small) to help me understand exactly what the circuits are doing. The original thread can be found at http://forum.allaboutcircuits.com/showthread.php?t=28481
To begin, R2 and R4 work together as a voltage divider to supply the "inverted signal" or probably more correctly named the "reference voltage". By my calculations, the reference voltage comes to ~ 0.009V into the op amp comparator.
I believe that the role of R6 is simply there to reduce the current to the LED. Is that accurate?
R1 and R3 look suspiciously like another voltage divider to me. However, the role of R5 confuses me. Do I calcuate the voltage going into the + side of the comparator using R1 and R3 only? Does R5 affect the voltage going into the + lead of the comparator?
Finally, since I'm using the LM 339 for the op amps, just what is the voltage comparison tolerance? What I really mean to ask is, at what voltage difference does the op amp decide that one voltage is greater than the other? I'm reading the data sheet but the terminology is new to me. Terms like, "Low Input Offset Current: +/- 5nA TYP" have limited meaning to me. Does that mean that if the current difference is greater than 5nA that the op amp triggers?
I feel pretty close to understanding how this circuit works, and therefore how to use these principles going forward. Thanks in advance for your help.
