Analyzing frequency response of audible sounds
TammyG
Joined Oct 29, 2008
I would like to like at the frequency response of audible sounds using an oscilloscope.
If I go to RadioShack and buy a simple electret microphone, can I simply connect the osciiloscope leads to the output of the microphone and ground?
A response would be most appreciated.
Tammy
scubasteve_911
Joined Dec 27, 2007
1,203
If you want to know frequency response, an oscilloscope is not what you want to use. You should be using a spectrum analyzer, which gives you the amplitude of discrete frequencies across a spectrum.
Buy a computer microphone and use that, you can find programs that will give you the FFT of the signal. Matlab can do this.
Steve
