Analyzing an op amp
Discussion in 'General Electronics Chat' started by JasonMcG, Apr 28, 2013.
  1. JasonMcG
    Apr 27, 2013
    24
    See image:
    http://i1362.photobucket.com/albums/r687/JasonMcG1/Circuit_zps98e971ed.jpg
    I have tried to decipher what i think is correct. Using the gain on each amplifier and multiplying it by the voltages i acquired Vout to be +1.9 volts. Need to know if i am correct. Also need to know what to do for part ii. Also where do you connect the battery in this circuit? Any and all help is much appreciated. Thanks.
    Jason M
  2. ScottWang
    Aug 23, 2012
    4,925
    777
    The 0.9V output voltage is right.
    How to connecting the batteries to the 741, where is the +9V of battery that it will be connecting to which is the +9V on the circuit, and where is the -9V of battery that it will be connecting to which is the -9V on the circuit.
  3. JasonMcG
    Apr 27, 2013
    24
    0.9V or 1.9V ?
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    The gain of inverting amplifier = -(9V*(Rf/Ri)) = -(9V * 0.1) = -0.9V
    The gain of noninverting amplifier = 9V*((Ri+Rf)/Ri) = 9V*(11/10) = 9.9V.
    The +V only 9V, so the output could not reach to 9.9V.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    You are both wrong.
    Jason, show your work.
  6. ScottWang
    Aug 23, 2012
    4,925
    777
    When I got the answer, I just felt the values is little strange, but that is according to the formular, so what's wrong with the formular or those values?
  7. JasonMcG
    Apr 27, 2013
    24
    I have renamed the components for easier referencing.
    See image:
    http://i1362.photobucket.com/albums/r687/JasonMcG1/Ciruit_3_zpsac535a8d.jpg
    Amp A: inverting
    Gain A = R2/R1 = -0.1
    -0.1x9V= -0.9V
    Amp B: non-inverting
    Gain B = 1+(R4/R3) = 11V
    11x0.1 = 1.1V
    Amp C: non-inverting 'buffer'
    Gain C = 1
    1x1.1 = 1.1V
    Amp D: 'Summing amp'
    G1=-(R7/R5) = +0.9V
    G2=-(R7/R6) = -11V
    R5//R6
    G3=1+(100/9.091) =1+11=12
    12x1 = 12V
    Therefore Vout = 0.9-11+12 = 1.9V
  8. screen1988
    Member
    Mar 7, 2013
    310
    I think in your image Vin = -0.1V => output of B: 11x(-0.1)= -1.1V
    Gain C = 1
    1x(-1.1) = -1.1V
    Vout = 0.9+11+12 = 23.9V
  9. Ron H
    Apr 14, 2005
    7,050
    657
  10. JasonMcG
    Apr 27, 2013
    24
    I have gone through it again and calculated Vout to be 23.9V. Is this the correct value?
  11. Jony130
    Feb 17, 2009
    3,990
    1,115
    No you are wrong. For Vcc equal to +9V LM741 won't give you more then 9V at the output.
  12. Ron H
    Apr 14, 2005
    7,050
    657
    If you had an ideal op amp with no limits on output voltage, that would be correct. As jony130 says, the output can never exceed the rail voltages. With a 741, and ±9V supplies, your output will never exceed ≈±8V.
    That is either a trick problem, or a very poorly designed one.
  13. JasonMcG
    Apr 27, 2013
    24
  14. Ron H
    Apr 14, 2005
    7,050
    657
    For now, just imagine that the RC network is not there, and the sine wave appears unattenuated at the output of op amp C. What would the voltage be at that node? What would the output of op amp D be?
  15. JasonMcG
    Apr 27, 2013
    24
    The output at the node would be 1.1V and at op amp D it would be 23.9V
  16. Ron H
    Apr 14, 2005
    7,050
    657
    You might want to think a little harder. A sine wave is not a DC voltage.
  17. JasonMcG
    Apr 27, 2013
    24
    It would have a max peak at 55mV and a minimum at -55mV
  18. Ron H
    Apr 14, 2005
    7,050
    657
    How did you come up with that? :confused:
  19. JasonMcG
    Apr 27, 2013
    24
    the output voltage being 1.1V =110mV peak to peak
    meaning 50mV up and 50mv down from the origin
  20. Ron H
    Apr 14, 2005
    7,050
    657
    I regret to inform you that 1.1V=1100mV, NOT 110 mV.:D
    Do you really think carefully before replying? I'm starting to feel like a babysitter.:rolleyes:
