Analyze sequential circuit
Discussion in 'Homework Help' started by mo2015mo, May 20, 2013.
  1. mo2015mo
    May 9, 2013
    157
    Hi guys ;) ,
    I have been having problem with the attached question (fig 1), I have tried to solve it as attached figure 2,
    Is this solution correct? IF Not ..why and what the correct solution..
  2. LDC3
    Apr 27, 2013
    920
    160
    Since B0 is always 1, then you can remove every other row in your state table. Why have it in there if it is not needed. You should state that B0 is always 1 before the table so the professor will know why it is not included in the table.
    Since Q = B1, whenever Q is different from B1 as in the 7th, 8th, 15th, and 16th state, what will happen? What should you say on the table?
    mo2015mo likes this.
  3. mo2015mo
    May 9, 2013
    157
    How different ?? Q = B1
    I filled next state Q(t+1) by characteristic table for JK-flipflop
  4. LDC3
    Apr 27, 2013
    920
    160
    What I am saying is that since Q (an output) sets B1 (an input) to the same level, how can you have B1 as 0 when Q is forced to 1 since J is 1 ? What happens then ?
  5. mo2015mo
    May 9, 2013
    157
    it is toggling command :confused: :confused:
  6. mo2015mo
    May 9, 2013
    157
    Really did not understand.. :( Please explain more :)
  7. LDC3
    Apr 27, 2013
    920
    160
    OK, now that we established that the output Q toggles, that is then written in the state table. Does the toggling effect any other outputs (A>B, A=B) ?
  8. mo2015mo
    May 9, 2013
    157
    yes , because B1 = Q and B0=1
  9. LDC3
    Apr 27, 2013
    920
    160
    Do the outputs toggle continuously, or does a steady state develop ? If it toggles for more than 10 cycles (depending on the number of states), I would probably say it was continuously.
  10. mo2015mo
    May 9, 2013
    157
    yes, the outputs toggle continuously
    i have written all the probabilities of the output in the state table
    :confused: Use Don't care ?
  11. mo2015mo
    May 9, 2013
    157
    Where the wrong in the state table ?? J-k Column or Q(t+1) Column or external output??
  12. LDC3
    Apr 27, 2013
    920
    160
  13. mo2015mo
    May 9, 2013
    157
    ok ,i.e. my solution (fig3) is correct :)
    LDC3 likes this.
  14. LDC3
    Apr 27, 2013
    920
    160
    yes, it's correct
  15. mo2015mo
    May 9, 2013
    157
    LDC3
    thanks you for help me
