Analyze circuit to determine output:
Discussion in 'General Electronics Chat' started by mbxs3, Aug 27, 2011.
  1. mbxs3
    Thread Starter Active Member
    Oct 14, 2009
    143
    Can someone please analyze this circuit and determine what the output voltage will be?
  2. Kermit2
    Feb 5, 2010
    3,857
    968
    That seems to be a 3 volt zener, right?
    What happens when you make it a 5 volt, or a 10 volt zener?
    Believe it or not, those are hints at what the output will be.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    The primary intent is for the circuit to be a ~5 second delay. Once C1 charges to ~1,7v, the output is turned on.
    You should see somewhere around 23.1v-23.5v depending on the output load; load shouldn't draw more than about 25mA without causing problems.
    BTW, that's a 4.7v 1W Zener.
    mbxs3 likes this.
  4. Kermit2
    Feb 5, 2010
    3,857
    968
    mbxs3 and SgtWookie like this.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Thanks, Kermit2 - I realized that in my state of exhaustion yesterday evening (lots of yard work in humid 100°F weather) that I'd transposed the 1N4372A to 1N4732A; the latter of which is in fact a 4.7v 1 Watt Zener.
    That DOES change the output voltage, but I'll need to throw a model for that Zener into my simulator to make sure.
    [eta]
    Couldn't find a model for that particular diode in a short period of time; but the output should now be approximately 25v, give or take some, depending on the load.
  6. Kermit2
    Feb 5, 2010
    3,857
    968
    We all make mistakes, and I seem to make more than my fair share most days.
  7. mbxs3
    Oct 14, 2009
    143
    Thanks for breaking it down for me guys.
    The output load is a 26vdc relay that is PCB mounted. I don't know the current requirements of the relay.
    I guess that when the signal at power source #2 is high, the output of the circuit is capable of energizing the relay, when the signal at power source #2 goes low, the relay is de-energized.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    What is the part number of the relay? I could see if it would simulate OK or not, but I'd need to know the resistance of the coil.
    If the relay does not have a built-in diode, or if the diode is burned open, it would take out (fry) the Zener and Q6 rather quickly
  9. mbxs3
    Oct 14, 2009
    143
    Relay part number is W260-A1A-004L1.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Leach Int'l
    Interesting, those are mil-spec parts.
    http://www.leachintl2.com/english/english1/vol0/properties/00028.html
    The coil has 700 Ohms resistance, so ~35.7mA current.
    I'm seeing about 24.5v with that much of a load on it, and it takes an extra second for the voltage to reach that point.
    Note that there is no reverse-EMF suppression diode in these relays. This circuit really needs a reverse-EMF diode added, or Q6 is going to be blasted.
    What's this circuit in? A vintage military aircraft? We used extremely similar relays in F-4 Phantoms.
  11. mbxs3
    Oct 14, 2009
    143
    Yeah, P-3's.
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Cool. It's amazing that they're still flying those birds; they were old when I was on active duty.
    I added some more test points so that you can get an idea of the voltages over time. If you need anything else, holler. ;)
  13. mbxs3
    Oct 14, 2009
    143
    Thanks Sgt. They are some oldies. As always, I appreciate the info you provide.
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    You're welcome - anything to keep NAVAIR up there. ;)
