does anyone know how i can use matlab/simulink to derive the time solution for a simulated series LCR circuit? (i have the simulation of the step responce from the transfer function)
The attached Scilab based simulation of a series LCR circuit is probably what the OP has in mind. It uses an incremental (time-stepped) method to find the solution of the differential equations which describe the circuit behavior.
