Analysing equations of inductance and capacitance
Discussion in 'Physics' started by kiroma, Jun 9, 2015.
  1. kiroma
    Apr 30, 2014
    40
    Hello.
    Ic=C*dv/dt comes from Q=CV.
    V(Voltage across inductor)=L*di/dt comes from what?
    I found that integral of (v*dt)=L*integral of (di)
    Replacing v by R*I, and replacing I by dq/dt we have that
    Integral of (R*dq/dt*dt)=L*integral of (di)
    Integral of (R*dq)=L*integral of (di)
    OBS.: limits are from 0 and 0 to q and i, respectively.
    R*Q=L*I
    L=RQ/I
    So that means inductance is proportional to the resistance of the inductor?
    I think I did a big mistake and a maybe a big confusion but, at least, I tried to find.
    The question remains the same.
  2. studiot
    Nov 9, 2007
    5,005
    515
    This doesn't work.
    The ideal inductor has zero resistance so your second equation above, is nonsense. Where did you get the idea that v = ir in an inductive circuit?
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,554
    515
    If i understand you right i think you want to go back to Faraday which would lead to:
    N*dPhi/dt=L*di/dt
    for N the number of turns, Phi the magnetic flux, L the inductance, i the current.
    or another interesting way to look at it is:
    dPhi/di=L/N
    kiroma likes this.
  4. kiroma
    Apr 30, 2014
    40
    Haha
    That's why I thought I was doing a big mistake
    Answering your question, sincerely, I don't know, haha.
    Thank you MrAl.
  5. kiroma
    Apr 30, 2014
    40
    So it means that N*dPhi/dt=Vl=L*di/dt?
    Did Faraday found this?
  6. MrAl
    Jun 17, 2014
    2,554
    515
    Faraday found:
    E=N*dPhi/dt
    or the signed form:
    E=-N*dPhi/dt (i think attributed to Lenz)
    L is the constant of proportionality that relates the flux to the current:
    L=Phi/I
    just as capacitance C is the constant of proportionality that relates the charge to the voltage:
    C=Q/V
    L has a physical origin just as C has a physical origin, both dependent on the geometry.
    Another view is through the stored energy:
    U=(1/2)*C*V^2
    U=(1/2)*L*I^2
    Inductance is the dual of capacitance, so often when you see voltage in a capacitor equation you'll see current in an inductor equation...as current is the dual of voltage.
    L is the first letter of Lenz, in his honor (almost same equation as Faraday).
    C is the first letter of Capacitor, in honor of Mr. Capacitor (just kidding) :)
    kiroma likes this.
  7. kiroma
    Apr 30, 2014
    40
    So it's correct to say that E=-N*dPhi/dt (as my professor said, when I wrote on the board the equation N*dPhi/dt=L*di/dt, "isn't a minus missing?!" Lol) and not E=N*dPhi/dt (incorrect)
    Am I right?
  8. MrAl
    Jun 17, 2014
    2,554
    515
    Yes, and i think it was Lenz who clarified the sign of the result, not Faraday, but dont quote me on this rather look it up on the web and maybe you can make a note here in this thread.
    kiroma likes this.
  9. kiroma
    Apr 30, 2014
    40
    I think this is clear in the following page:
    http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html
    Where is attributed to Lenz the minus sign.
  10. MrAl
    Jun 17, 2014
    2,554
    515
    Yes i see they put the little minus sign with the note "Lenz's Law" pointing to it so it modifies Faraday.
  11. gbegks
    Jul 15, 2015
    kiroma likes this.
