Analyses for bipolar junction transistor
Discussion in 'General Electronics Chat' started by full, Oct 25, 2014.
  1. full
    May 3, 2014
    225
    Hello everyone
    I do Analyses for bipolar junction transistor (BJT) PNP on A ,B & C .
    for analysis A the current flow from emitter to base & collector .
    for analysis B the current flow from emitter to base & collector but there is source in emitter .
    for analysis C the current flow from emitter to base & collector but there is source in emitter .
    please check my analytic true?
    please If there is anything unclear told me.....
    thanks
  2. full
    May 3, 2014
    225
    Analysis update :
  3. shteii01
    Feb 19, 2010
    3,501
    511
    It helps to let people know that you are talking about PNP, PNP, NPN transistors.
  4. full
    May 3, 2014
    225
    sir this is PNP
    thanks
  5. full
    May 3, 2014
    225
    update :
    analyses :
    I think there is wrong in analysis B in emitter to base (Vth) but I do analysis should they (vth ) in positive not in negative .
    and there is wrong in analysis C in emitter to base (-Vre & -Vth) same problem in analysis B .
    I think there are problem in my loops :confused:
  6. Jony130
    Feb 17, 2009
    3,991
    1,115
  7. MrChips
    Oct 2, 2009
    12,635
    3,453
    Don't let the change of polarity confuse you. All three circuits have the same configuration and hence the analysis is the same.
    The analysis is still the same for a NPN transistor.
  8. full
    May 3, 2014
    225
    update:
  9. Jony130
    Feb 17, 2009
    3,991
    1,115
    Why you cannot stick to one convention when doing KVL ?
    For case A
    -VRe - Vbe - VRth + Vth = 0
    -VRe - Vec - VRc + Vcc = 0
    Also notice that case B and C are identical (Case B is turned 180 degrees case C). So KVL also must look identical.
    Also you made a error in case B, why Vth is negative ??
    Also notice that the only difference between case A and B&C is reference point (GND).
    So the current will stay the same but the voltage will change.
    Try analyze this circuit very careful.
    And for example do you understand why the base voltage is -1.6V in case A and 7.4V in case B ?
  10. full
    May 3, 2014
    225
    for first circuit :
    Vee -Vre + Vbe - Vth - Vth
    second circuit:
    the first circuit and second is same
    no
    sorry for late because I have exams
    thanks
  11. full
    May 3, 2014
    225
    I have another circuit :
    me Vth and DC analysis true?
      File size:
      399 KB
      45
  12. Jony130
    Feb 17, 2009
    3,991
    1,115
    Very good, but why you drew your circuit upside down ?
    First you need to understand what GND is, so please read this
    http://forum.allaboutcircuits.com/threads/ground-node.102921/
    Once you understand what GND is. Pleas notice where GND is in the first circuit. Ground is at positive battery terminal.
    And because the voltage at base is measured with respect to ground, this voltage is equal to the voltage drop across R2 resistor with minus sign.
    But if our ground is negative terminal then voltage at base is equal to VR1 voltage drop.
    On the other hand the collector voltage for the first circuit is a sum of a voltages Vc = VRe + Vce. But in second circuit Vc is simply -VRc.
    Ve for the first circuit is -VRe but for second circuit Ve = VRc + Vce
    And this is why this voltages are shifted by 9V depends on where the GND is.
    VB = 7.4V but if we change the ground the base voltage will be shift down to 7.4V - 9V = -1.6V
  13. full
    May 3, 2014
    225
    Hello again
    The Av is negative or positive?
    I think is positive
  14. Jony130
    Feb 17, 2009
    3,991
    1,115
    If Av is a voltage gain for CE amplifier, the gain is negative but usually we ignore this "minus" sign. Because this only informs us about 180 degree phase shift.
    full likes this.
  15. full
    May 3, 2014
    225
    If do not put "minus" on Av a voltage gain ,is mean wrong?
    actually when did exam test , didn't put minus on Av
    thanks
