Hello all,
I'm working on a project and I'm facing a problem on my next task. I need to convert the analogue output of a dual pot device to a PWM signal to be read by an other device. Both signals voltage are 5v and the PWM frequency is 250±20 Hz.
ANALOGUE SIGNAL ----> (ANALOG to PWM CONVERTER DEVICE) ----> PWM SIGNAL
Does anybody knows witch microcontroller could I use to build this converter?
Thanks in advance!
Thanks in advance!
