Analogue pros and cons
Discussion in 'General Electronics Chat' started by sparks5, Mar 23, 2012.
  1. sparks5
    Mar 23, 2012
    Can anyone explain the pros and cons for the use of 4-20mA and 0-5v, 10v signals.
  2. crutschow
    Mar 14, 2008
    13,508
    3,385
    4-20mA current signals are used where you want a two wire connection over a long distance and need to minimize interference, since it has good common-mode voltage noise rejection. It also allows both signal and power for remote sensors to be transmitted over the same two wires.
    0-5V or 10V single-ended voltage signals are typically send for short distances within an electronic box where common-mode noise is not a problem
  3. sparks5
    Mar 23, 2012
    Thanks for the info. I have a 20 m run through twisted pair cable s
    o 4-20mA it is
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    An other advantage of the 4-20 mA system, is that you can see a wire break.
    If there is a wire break, no current will be present.
    Bertus
