Analogue Multimeter
Discussion in 'General Electronics Chat' started by dark music, Jan 12, 2012.
  1. dark music
    Jan 12, 2012
    can i measure AC current with a analogue multimeter. i'm just a student. so forgive me if this is a dumb question.
  2. mcgyvr
    Oct 15, 2009
    4,789
    974
    Saying "multimeter" means it has multiple functions..one of those is typically a current meter.. Did you mean multimeter or volt meter.
    Read the front.. Does it show an A~ at one section along the dial..
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    A simple meter might not be equipped for current at all, while a more comprehensive one probably would measure both AC and DC current. You would really have to refer to the particular meter's specifications - or the meter itself.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    If your meter doesn't have AC Amps, or if the range is too low, there's another alternative. Insert a small ohmic resistor into the wire carrying the current. The value should be so small it won't affect the operation of the circuit ( fractional ohm resistors are available with good tolerances ) Then just use the AC volts function and ohm's law to determine the current.
