analogue components help
Discussion in 'General Electronics Chat' started by dogg, Jul 2, 2014.
  1. dogg
    Jul 2, 2014
    Hi new to this so sorry if I the wrong place
    Im in need of some questions answered and some help understanding them about analohue electronic components
    how do the terms on amd off amd high resistance and low resistance relate to BJT
    If a darlington pair has a base current of 1mA and the current through the collector is 500mA what is the gain of the transistor
    describing SCR ratings of reverse voltage and forward voltage
  2. Robin Mitchell
    Oct 25, 2009
    738
    207
    Well, if a transistor is "on" then current can flow through with relative ease, that is it has a low resistance. If the transistor is "off" then current flow is either small or non existance, in other words it has a high resistance.
    If a darlington transistor has 1mA base current with a collector current of 500mA then the gain is the output divided by the input, in this case 500mA / 1mA = 500
  3. dogg
    Jul 2, 2014
    Okay thanks that makes it easier
    Also do you know what the purpose of dual charger circuit and zener diode as voltage stabiliser is and what the diode is doing to the current or voltage,
  4. shteii01
    Feb 19, 2010
    3,507
    512
    Sounds suspiciously like Homework.
    ErnieM and KJ6EAD like this.
  5. dogg
    Jul 2, 2014
    Could be.. its hard
