Analog vs digital s/g
Discussion in 'General Electronics Chat' started by aamirali, Apr 4, 2012.
  1. aamirali
    Feb 2, 2012
    415
    A DC voltgae of 5V (lets say o/p of 7805).
    Is it digital or analog.
    Analog because it is continuous signal over entire time range.?????????
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is analog because it varies it's internal resistance linearly to create 5VDC on the output.
    A SMPS (switching mod power supply) turns a output transistor on/off (the two most efficient states for a switching device) and averages the voltage around the voltage set point. As a result, it is much more efficient, if noisier.
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    All digital signals are analog.
    Not all analog signals are digital.
    ErnieM likes this.
  4. Brownout
    Jan 10, 2012
    2,375
    998
    A DC voltage level is neither analog nor digital, as those labels refer to how information is processed. A DC voltage, as in a supply voltage, isn't information. However, the 7805, being a linear regulator, would be considered an analog circuit.
    c0de3 and BSomer like this.
  5. aamirali
    Feb 2, 2012
    415
    so can we reach at some conclusion
    its analog (not 7805, its general dc voltage)
    digital
    both?????????
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    nope.....!
  7. nerdegutta
    Dec 15, 2009
    2,565
    805
    See post #4. That was a good answer.
  8. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Yes. Sometimes.
    It depends...
  9. vpoko
    Member
    Jan 5, 2012
    258
    47
    Analog/digital refers to signal and signal requires change (in voltage, current, whatever). If the change is continuous, the signal is analog. If the change is discrete, the signal is digital. An unchanging voltage across a load will create a steady current, which isn't a signal and so isn't analog or digital.
  10. R!f@@
    Apr 2, 2009
    8,785
    771
    Power supply current are exactly not referred as Digital or analog but to confuse people they are stated as Digital supply or Digital ground or analog ground. So n00bs tend to believe it is a digital supply or analog supply which a standard 7805 can be refereed to both it is just a power supply regulator.
    It's how they are used or in which type of circuit they supply power gives the name Digital or Analog.
    On the other hand, a supply can be said a digital supply if the regulator circuitry or control uses a digital processor to do all the sensing and controls. Then it is a mostly Digital. Or say an SMPS is sorta digital but analog current do exist with in it.
    Confusing, ain't it?
  11. WBahn
    Mar 31, 2012
    18,085
    4,917
    To confuse matters even worse, the terms "analog supply" and "digital supply" are also used in the context of "the supply that provides power to the analog (or digital) circuitry". In this use, the supply isn't categorized by how it works, but what it supplies power to. This usage is common in situations in which a designer is working with a mixed-signal system, particularly on an integrated circuit. Each supply normally has different requirements, particularly in terms of tolerable noise level. Sometimes it is important that the analog supply be linear while the digital supply can be a switch-mode, but it is not uncommon for both to have to be linear in order to meat the noise requirements (which are usually driven by the need to keep noise in the analog circuitry to a minimum with the noise coupling from the digital sections into the analog sections putting limits on the digital supply tighter than what the digital circuitry, itself, demands.
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    Actually, the terms linear power supply and SMPS (switching mode power supply) are pretty clear cut.
  13. WBahn
    Mar 31, 2012
    18,085
    4,917
    I don't think anyone has said that "linear" and "switched-mode", when used as an adjective for a power supply, are ambiguous. I said that "analog" and "digitial" are ambiguous.
