Analog voltmeter modification
Discussion in 'The Projects Forum' started by nathomas, Mar 9, 2011.
  1. nathomas
    Mar 3, 2011
    82
    I have to measure voltage between 0.75v and 3V. The voltmeter should not go down to 0 and I want to scale the whole voltmeter between this voltage. I am using the voltmeter to measure the output of an rtd sensor whose output is scaled from 0-5 V but will be measuring around only at the above given voltage of 0.75-3V. could anybody suggest an idea..thanks.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Adjust the zero set screw so zero is 0.75V, of course you'll need a new scale.
    nathomas likes this.
  3. nathomas
    Mar 3, 2011
    82
    But how do I scale the voltmeter that reads 0-5V to read 0-2.5v. i.e
    1-2.5V ==> 0 - 5V ?
    So when we are actually getting 2.5V the voltmeter should be showing 5V.
    And when we re getting 1V the voltmeter should show 0V.
  4. wayneh
    Sep 9, 2010
    12,396
    3,246
    Use an op-amp. It will allow setting both an offset and a scale factor. The downside is you'll need to power it and have a little PCB for it.
    Why not just use a cheap DVM - they're under $5 - and use a quick lookup table printed out of Excel. For example, 2.15v = 37°.
  5. nathomas
    Mar 3, 2011
    82
    Thanks Wayneh. well I am going to use a pcb as I have more components for the circuit. completely forgot abt using an op amp. i cannot use a dvm as thats the design requirement. how can i offset the 0v to a 1v in an opamp.
  6. wayneh
    Sep 9, 2010
    12,396
    3,246
    One input to the op-amp is established by a voltage divider including a pot, supplied with a voltage reference. The pot can then be used to dial in the offset voltage. Gain is set by a feedback loop from the output.
  7. Kermit2
    Feb 5, 2010
    3,854
    968
  8. nathomas
    Mar 3, 2011
    82
    @Kermit:None of the links on the page work.but thanks.now i know what Im looking for.
  9. nathomas
    Mar 3, 2011
    82
    I saw this article about using two voltage regulators as ESV but I cannot seem to find the circuit diagram. And if I thought of using the zener diode method, are there 1v zener diodes in the market?
  10. nathomas
    Mar 3, 2011
    82
    the ESV in all the designs mentioned uses an ammeter rather than a voltmeter. I have an existing voltmeter that I want to use.
  11. Kermit2
    Feb 5, 2010
    3,854
    968
