analog to digital
Discussion in 'General Electronics Chat' started by adamclark, Nov 4, 2013.
  1. adamclark
    Oct 4, 2013
    472
    6
    hello again,, how hard would it be to make the volt/amp guage of my psu a digital display in stead of analog? its a variable supply with a pot. knob not a switch so when rolling up the voltage the display would have to roll with it?
  2. adamclark
    Oct 4, 2013
    472
    6
    figured I would add a picture of my psu...
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    probably simple..
    If the analog meter is full scale (so if Vin to meter = Vout) then just buy a digital meter and hook it up to it.... Note you will need a constant voltage for the power supply of the digital meter too..
  4. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
  5. adamclark
    Oct 4, 2013
    472
    6
    so that's it? the digital meter hooks right up to the same wires that the analog one uses? I just figured there would be something tricky about it..
  6. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    We can make it tricky if you prefer. ;)
    The Red Lion PDF give you an idea what is needed, there are various models with varying complexity.
    Max.
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    Digital panel meters are not cheap. Shop around.
    Or roll your own.
  8. MrChips
    Oct 2, 2009
    12,624
    3,451
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
    Easy. We used to get self contained dig displays where the full scale was selectable as either 200 mV or 2V.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Be careful... A lot of the inexpensive DPMs cannot share a common connection between their own power pins and the negative of the voltage they are measuring... The more expensive ones usually can...
  11. adamclark
    Oct 4, 2013
    472
    6
    I think I would like to build my own using 7 segment led displays.. I feel I could a lot from a project like that.. so where do I start?
  12. ScottWang
    Aug 23, 2012
    4,925
    777
    You can using ICL7107 for LED, and it's easy to change when the LED was damaged.
  13. adamclark
    Oct 4, 2013
    472
    6
    I was just reading on that ic... it seems amazing that it does everything that's needed and then some.. I wonder if its available at the local esco?
  14. ScottWang
    Aug 23, 2012
    4,925
    777
    Here is the 7107 LED sample.
