Hi everybody,
I am on a project where I have to switch between different filters for different frequencies. Now, the solution I have not to alter the signal, is to put/remove a sort of jumper. However, I was thinking about replacing the 'manual' jumper by a 4066 analog switch, but I am just afraid that the signal will be filtered / altered by this chip. I am working in UHF (300-400MHz) and I cannot find any info related to the frequency.
What do you think ?
EDIT;
I finally found a better datasheet, but it looks like it is not suitable for UHF. Actually, I am deducing it, because the typical frequencies are around 10MHz.
Does it exist such a switch for high frequencies ?
What do you think ?
EDIT;
