I am working on a 5 axis rotational table with 6 sensors. These sensors allow me to know the position based on an analog signal from each of them. Each sensor provide me 4 signal from 0 to 5 Volts with a current range from 0-20 mA. The four signals are A+ A- B+ and B-. Using differential mode I obtain signal A and B. To obtain the position I find the angle using arc-tan(B/A) and the length of the vector using sqrt((A^2)+(B^2))
I have been doing some test and my readings have some noise. The main noise source is some leaking power from the sensor that is affecting the readings. I think that using an optocoupler will make a galvanic isolation that will allow me to separate the grounds from the sensors and the ground from the DAC. I think I am going through the right direction but this is my first noise isolation project.
I also though about electromagnetic noise but all the cables are shielded and separated from high voltage cables. Also, the DAC system is placed outside of the machine with a Faraday shield and all the cables from and to the DAC are completely shield.
I have been trying different setups and designs to implement the optocouplers but my first and second prototype had a lot of problem with the output voltage and I had to use a graduable resistance and tweek it to be able to obtain a similar result for the output signal but I cannot do this for all the signals. My current design is "Attachment 1" .
For prototyping I used an Avago HCNR200 optocoupler and as my amplifier I used an TL074CN fro Texas Instruments. The resistances R1 and R3 were 10.000 ohm and R3 was 220ohm. I did not use capacitors because they will slow down my reading and I need a recording frequency of at least 15000 Hertz.
