Analog signal effects module
Discussion in 'Homework Help' started by novastorm17, Aug 5, 2013.
  1. novastorm17
    Aug 5, 2013
    Hey guys,
    For one of my electronics courses, we've been assigned to create an effects module - something similar to a synthesizer effect.
    There will be a input signal (probably from an oscillator circuit) into this module.
    What I need to do at the moment is create a basic block diagram of the signal processing that takes place in the effects module.
    I was looking at (but not limited to) doing something along the lines of a reverb effect.
    I'm fairly confident with my electronics knowledge, but this has got me stumped (for the moment).
    Perhaps something like:
    Input signal -> copy signal -------------------------------> sum -> output
    . . . . . . . . . . . . . . . . . . -> delay -> attenuate (tail off) -> sum
    Thanks for any help
    PS: No digital circuitry is allowed in the effects module
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    What has got you stumped? What reverb is? Conceptually how it is accomplished? Physically how it is implemented? What?
    What have you found from your research into reverb?
  3. studiot
    Nov 9, 2007
    5,005
    515
    You will need to know what the following circuits and terms are
    Mixer
    Envelope shaper
    Signal attack
    Signal decay
    Spring line (if you must have non digital reverb)
    Transducer
    If you do not know what these are, look them up, ask for help if you need more.
  4. nsaspook
    Aug 27, 2009
    3,016
    2,371
