Hey guys,
I'm trying to figure out a way to get 2 different signals to 2 motor controllers that take a 0-5V input. Basically, the motors work as a differential in a go kart with a split axle. Right now it is set up so each controller gets the same signal from the throttle pot. Is there a way to get 2 different signals to the controllers that change based on an additional signal such as a pot on the steering wheel?
Also, I've been doing some research and I came across a passive mixer circuit. I'm not sure if it will do what I want though (I'm a mechanical engineering student, so any electronics knowledge I learn on my own )
Thanks!
Chris
Thanks!
Chris
