Analog input voltage
Discussion in 'Embedded Systems and Microcontrollers' started by ecaits, Jul 30, 2014.
  1. ecaits
    Jan 6, 2014
    52
    Dear Friends,
    I have two-three silly question in my mind...
    1. If I give more than 5V, say 10V to analog pin of ADC then what happen???
    2. If I give negative voltage to analog pin of ADC then what will happen???
    3. If I have 4-20mA output of sensor, can I use it as analog input??? OR First I need to convert 4-20mA to equivalent 0-5V??? If yes, How can I covert the same???
    I am using PIC16F877.
    Thank you in advance,
  2. hexreader
    Apr 16, 2011
    250
    82
    You forgot to give any information on exactly which ADC you are using.
    Some ADCs will happily accept +10 volts and negative volts, others will not.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A resistor of 249 Ohms 1% will convert currents as follows:
    .004 A * 249 Ohms = .996 Volts
    .010 A * 249 Ohms = 2.49 Volts
    .020 A * 249 Ohms = 4.98 Volts
    You can use an opamp configured a a voltage follower to avoid having the ADC input load the current loop.
  4. shteii01
    Feb 19, 2010
    3,500
    511
    There are voltage ADC, you will need to convert your current to voltage.
    There are current ADC, you feed current to the ADC.
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Generally you make any analog device very unhappy when you apply a voltage at any terminal greater then the positive supply, or less than ground (or the negative supply).
    Most input pins these days have "ESD" diodes to conduct energy to the power rails in case of a sttic zap. Often you can use these to keep your device safe from occasional short term overvoltages, but you need to insert a resistor in series with the input line.
  6. MrChips
    Oct 2, 2009
    12,635
    3,453
    Putting voltages greater than Vcc (Vdd) or lower than GND (Vss) isn't going to sit well with integrated circuits.
    In a worst case scenario, a CMOS circuit will latch-up, i.e. go into a SCR parasitic short circuit state that literally fries the chip.
    As Ernie points out, you need to put a resistor in series to limit the current plus voltage clamping diodes if the chip does not already have input protection diodes.
  7. wmodavis
    Oct 23, 2010
    737
    150
    See answers above.
    Papabravo likes this.
  8. ecaits
    Jan 6, 2014
    52
  9. ecaits
    Jan 6, 2014
    52
  10. ErnieM
    Apr 24, 2011
    7,436
    1,626
    My comments still stand:
    Also, max current into or out of a pin is 20mA max (it's listed as "Clamp Current" in Table 15.0). So a series 5K resistor keeps the ESD diode happy but provides a low imedance for the A2D.
    If the voltage goes to 10V the A2D reads 1023, if it goes below ground it reads 0. I would use a resistor below what Papabravo suggests so you can read a difference between a legit 20mA input and an open sensor (which could give you that 10V).
