Good Morning guys
I need some help urgently,I'm requested to design an Analog Four Quadrant dc motor speed control.I'm using a 555 timer to generate the pwm signal(20Khz) and I'm controlling my duty cycle using a variable resistor.I'm using mosfets for my H-Bridge circuit.I looking for a method on how to invert the 12V pwm signal output of 555 timer.I've tried using npn transistor but some how it does not invert,I think its becuase the 555 sinks and sources current,I've also tried using an op amp with a gain of 1 so that I just get the 180 degress phase shift,this also does not work,I'm getting a weird output.
Can someone pleased help me,my connections might be wrong so if u can please send me a topology that I can use.My email address is:andilemthembu@hotmail.com
