Analog Electronics Help?
Discussion in 'Homework Help' started by conclusionof, Nov 11, 2008.
  1. conclusionof
    Nov 11, 2008
  2. Firestorm
    Jan 24, 2005
    353
    What part do you not understand on this problem. Just break the problem up. This is a inverting op-amp, so use that formula. You can combine V1 and V2 with addition. If you have a more specific question, please don't hesitate to ask.
  3. mik3
    Feb 4, 2008
    4,846
    63
    Vo=-Vin*(R2/R1)
    if you take R1 as Z1 and R2 as Z2 then
    Z2=R and
    Z1=R+jωL
    thus
    Vo=-(V1+V2)*[R/(R+jωL)]
  4. conclusionof
    Nov 11, 2008
    I dont understand how to add V1 and V2 up since one of them in sinus function while other is in cosinus form.
    Also can we use here phasor method ? (Though I know it is not proper to use phasor if the frequencies are not same)
  5. mik3
    Feb 4, 2008
    4,846
    63
    If the frequencies are different you cant use phasors to add them. Just use trigonometric identities to add them or expand each sin or cos in a series form, take the most important bits and add them.
    What exactly V1 and V2 equal to?
  6. Firestorm
    Jan 24, 2005
    353
    You can convert the cos function to a sine function by adding a \pi/2 to the sine function:
    Ex:
    sin(A) = cos(A+\pi/2)
