I am currently building a guitar synthesizer which uses a pickup that requires +5v, -5v with an analog ground which is then sent into a rectifier. On the other side of the rectifier I have another +5v source with my digital ground, which at the moment is completely separate from the first source.
My question is, is there a way to power the first part of the circuit and the second part of the circuit using the same source without shorting the rectifier?
I'm going to be using batteries.
