Analog Devices 'Circuits from the Lab' Question
Discussion in 'General Electronics Chat' started by dannybeckett, Apr 18, 2013.
  1. dannybeckett
    Thread Starter Active Member
    Dec 9, 2009
    163
    Hello again.
    I have a question on a new analog devices reference design. This circuit employs transimpedance gain switching, which is what I am currently researching. They use the ADG633 CMOS switch to swap out the feedback network of the amplifier. I understand that the switch has an on resistance of about 50ohms, which in the feedback loop will add a 50ohm error to the gain. What I don't understand is how connecting another switch at the output of the device, nulls this error? This is demonstrated about 1/3 the way down the page:
    http://www.analog.com/en/circuits-from-the-lab/CN0312/vc.html
    Any clarity on this matter would be greatly appreciated!
  2. joeyd999
    Jun 6, 2011
    2,757
    2,936
    Yes, this is strange. The output would have an impedance of Ron, and the Vo would be dependent on the subsequent load. Seems the only way the Rons would cancel would to force Iout = Iphotodiode.
    Am I wrong?
  3. crutschow
    Mar 14, 2008
    13,505
    3,376
    Since the left side of the switches are inside the feedback loop, their resistance will not affect the output at the junction of the switch pair. The op amp will force its output voltage to whatever is needed to overcome the switch resistance to maintain the voltage at the junction of the switch pair equal to Id x Rf.
    But the output load at Vo must be a very high impedance (such as a non-inverting CMOS op amp circuit) to minimize any error due to load current through the output side of the switches.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    The left hand switch puts Ron inside the feedback loop. The second switch selects which feedback loop you are monitoring. If you need lower output impedance, add a voltage follower.
    EDIT: Carl beat me to it.:D He also explained it better than I.
  5. joeyd999
    Jun 6, 2011
    2,757
    2,936
    Dang...you're right, Crutshow...I made the mistake of concentrating on what the text was saying, and not on the picture.
  6. dannybeckett
    Dec 9, 2009
    163
    OK that makes sense - but, would the following circuit not achieve exactly the same outcome but use less components, and have a lower output impedance?
  7. dannybeckett
    Dec 9, 2009
    163
    nope it wouldn't, the 52 ohm offset would exist in that configuration! cheers for clearing this up =]
