Analog audio and video inputs
Discussion in 'The Projects Forum' started by skybox, Aug 24, 2009.
  1. skybox
    Thread Starter Active Member
    Mar 2, 2009
    68
    Hi guys,
    My design requires an audio and video input (analog) from a source. I believe both signals are analog. Being new to this, what design considerations should I keep in mind. I know I should have separate grounds for both signals. As for the input to the connector, what type of components should I put in to reduce noise?
    X and Y are my inputs to the two sources
    X <---- VIDEO_IN
    Y <----AUDIO_IN
    Thanks in advance.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It might be important to know if the audio and video outputs were both anaolg. If so, and they come from a camera or similar device so the circuits producing those outputs are powered from the same voltage source, then the audio and video grounds will be common.
    As to noise reduction, what is the nature of the noise that you expect?
